DiabloSport® - inTune i3™ Programmer
Cadillac CTS 2014, inTune i3™ Programmer by DiabloSport®.
Thanks for the input Racer-X...As a Apt dweller, we're not allowed to work on our cars in the parking lot (besides cleaning or changing a tire...minor stuff), I have the basic 3.6 DI LFX motor, K&N and Borla muffler system. I wanted to give Will OverKill a chance, but he doesn't answer emails....which leaves Trifecta...but they don't allow any mods, like 80mm TB or pro-charger (my be my next year project) . I just want my girl to be quicker. I haven't reach the speed limiter!!! 140 and she was still trying to pullI've worked on vehicles that have been "tuned" with those. And my tuner expert has had experience with those and with other "tune in a box" type devices like that.
The one you linked is 50 states legal (even in CA, where it is CARB approved and has an EO #). That means it really doesn't do much. If you're running weird tire sizes, or you've changed the final drive gears, that one can fix your speedometer. It can also adjust cooling fan operation. If you're hitting the rev limiter a lot or hitting the electronic speed limiter, it can adjust (remove) those feature as well. And finally, it can make some adjustments to shift mapping for the transmission.
It won't adjust the base fueling maps, the base ignition maps or the VVT maps. It can make minor adjustments to WOT fueling (possibly only in the lean direction from stock, I don't remember).
Whether or not it's useful depends on the mods you've done to your engine and drive line. Like I said above, it'll do simple stuff like correct the speedo for alternate gears/tires and adjust cooling fan operation. It won't let you do enough to compensate for MACE cams and tuned headers or anything like that.
With any of the "tune in a box" devices, always ask the seller/maker if the device "locks" your PCM so that it can't be programmed by other tuners. If it does, avoid it like the plague. One of the "features" listed for that one is "One-time unlocked PCM cross shipment" and I'd want to know exactly what that means. If you use one of those that locks the PCM and then take it to a professional tuner, the tuner will need a fresh PCM in order to do anything. I think some of them lock it to the point where even the dealership can't restore the firmware with the factory original stuff.
That's too much $$$ for such a small increase. They say "the 50-state inTune i3 is not CMR compatible", what is CMR?I doubt that Diablo device will do anything useful with a bigger throttle body. I know it won't help with any kind of forced induction.
The fine print, once you select the engine (3.6L, gas), includes this: "Power Level 2 (91 Octane Performance Tune): 8 HP, 9 TQ "
My dyno tuning guy charges about $50 over that discounted CarID price for a dyno tune on any LSx V8 (including whatever mods you've done). He pulled well over 400 WHP out of the LS1+mods powered 1978 Datsun "570Z" I helped build with a friend. I'm not sure if he does HFV6 engines, but those will probably be more.
CMR is a custom tune. I can't remember what CMR stands for, but in DiabloSport speak, if you use this device, you can't do a custom dyno tune over and above the tune you get from this device. That makes me even more nervous because that may mean that it locks/encrypts the PCM data so that only this device can work with it.
Some of the Cadillacs That Can Be Custom Tuned (Engine & Auto Tranny) |
2004 - 05 Cadillac CTS-V |
2006 – 2009 Cadillac CTS-V |
2006 – 2009 Cadillac DTS, STS & XLR with the 4.4L S.C. & the 4.6L engines |
2006 Cadillac STS |
2007 - 2015 T42 Transmission Controller - 4 speed Automatic |
2007 - 2018 T43 Transmission Controller - 6 speed Automatic |
2010 – 2011 Cadillac DTS 4.6L |
2010 – 2015 Cadillac CTS-V |
2010 Cadillac STS 4.6L |
2013 - 2015 Cadillac XTS 3.6L |
2013 - 2016 Cadillac SRX 3.6L |
2013 Cadillac ATS 2.0L, 3.6L |
2014 - 2015 Cadillac ATS 2.0L, 2.5L |
2014 - 2015 Cadillac CTS 2.0L |
2014 – 2017 Cadillac CTS 3.6L Turbo |
2014 Cadillac CTS 3.0L |
2015 - 2016 T87 Transmission Controller - 8 speed Automatic |
2015 – 2017 Cadillac XTS 3.6L Turbo |
2016 – 2017 Cadillac CTS-V |
2007 - 08 V8 Trucks & SUVs (CAN Bus E38 ECM) |
2007 - 14 V6 4.3L Trucks & SUVs (CAN Bus E37 ECM) |
2008 – 2009 Cadillac SRX 4.6L |
2009 - 15 V8 Trucks & SUVs (CAN Bus E38 ECM except L96 6.0L Heavy Duty Trucks) |
2011 - 18 Heavy-duty Trucks with L96 6.0L engine (CAN Bus E78 ECM) |
2012 - 2013 Cadillac CTS 3.0L, 3.6L |
2012 Cadillac SRX 3.6L |
2014 - 18 V6 & V8 Trucks & SUVs (CAN Bus E92 ECM) |
2014 Cadillac ATS 3.6L |
ECM - Eprom Based |
90 Cadillac LW2, 4.5L, V8 |
91 - 92 Allante LQ6 4.5L V8 |
91 - 93 Cadillac L26, 4.9L, V8 |
91 Cadillac L26, 4.9L, V8 |
91 -93 Cadillac L26, 4.9L, V8 |
91 - 92 Cadillac L26, 4.9L, V8 |
94 - 95 Cadillac L26, 4.9L, V8 |
What is your turnaround for tunes?Your Welcome wcthunder
Sorry not trying to talk over peoples heads, but I have been tuning since 1994 and all this is second nature for me
This is not the whole list below just for Cadillacs, but ones I know of offhand
As I tune most GM vehicles that have gas engines
This can be done via emails and the person who has the vehicle needs a OBD-II scanner that records while
they drive, and they email that to me, so I then know exactly what each vehicle is doing and how I bias the tune
for the engine and the auto tranny if it has one to include elevation the vehicle is at, type of mods installed, age of vehicle, weather, gas used and how the owner drives it.
Then needs a flash tool that allows the owner to save the original GM calibrations and the tunes I email them
to flash in to the PCM and/or TCM (engine and auto tranny)
This requires having the use of a laptop that uses MS Windows OS.
Some of the Cadillacs That Can Be Custom Tuned (Engine & Auto Tranny) 2004 - 05 Cadillac CTS-V 2006 – 2009 Cadillac CTS-V 2006 – 2009 Cadillac DTS, STS & XLR with the 4.4L S.C. & the 4.6L engines 2006 Cadillac STS 2007 - 2015 T42 Transmission Controller - 4 speed Automatic 2007 - 2018 T43 Transmission Controller - 6 speed Automatic 2010 – 2011 Cadillac DTS 4.6L 2010 – 2015 Cadillac CTS-V 2010 Cadillac STS 4.6L 2013 - 2015 Cadillac XTS 3.6L 2013 - 2016 Cadillac SRX 3.6L 2013 Cadillac ATS 2.0L, 3.6L 2014 - 2015 Cadillac ATS 2.0L, 2.5L 2014 - 2015 Cadillac CTS 2.0L 2014 – 2017 Cadillac CTS 3.6L Turbo 2014 Cadillac CTS 3.0L 2015 - 2016 T87 Transmission Controller - 8 speed Automatic 2015 – 2017 Cadillac XTS 3.6L Turbo 2016 – 2017 Cadillac CTS-V 2007 - 08 V8 Trucks & SUVs (CAN Bus E38 ECM) 2007 - 14 V6 4.3L Trucks & SUVs (CAN Bus E37 ECM) 2008 – 2009 Cadillac SRX 4.6L 2009 - 15 V8 Trucks & SUVs (CAN Bus E38 ECM except L96 6.0L Heavy Duty Trucks) 2011 - 18 Heavy-duty Trucks with L96 6.0L engine (CAN Bus E78 ECM) 2012 - 2013 Cadillac CTS 3.0L, 3.6L 2012 Cadillac SRX 3.6L 2014 - 18 V6 & V8 Trucks & SUVs (CAN Bus E92 ECM) 2014 Cadillac ATS 3.6L ECM - Eprom Based 90 Cadillac LW2, 4.5L, V8 91 - 92 Allante LQ6 4.5L V8 91 - 93 Cadillac L26, 4.9L, V8 91 Cadillac L26, 4.9L, V8 91 -93 Cadillac L26, 4.9L, V8 91 - 92 Cadillac L26, 4.9L, V8 94 - 95 Cadillac L26, 4.9L, V8 91 Cadillac L26, 4.9L, V8
