Has anyone done the K&N Cold Air Intake kit?
2.2K views 16 replies 7 participants last post by  cw_esq
Just wondering if I could get some input from others who have done this kit. I installed mine a few hours ago, while I had the battery disconnected and can barely tell any difference!
Maybe the vehicle needs to driven more to relearn all its engine settings? I know some take longer than others so idk there... I only drove it for about 20 mins...
#2 ·
You probably paid a lot of money for nothing other than bling and noise.. The vehicle already had a more-than-adequate CAI straight from the factory. Several other threads over the years on this hype.
#4 ·
A few years ago Jay Leno had one of the lead Mustang engineers on his show and asked him whether cold air intakes were worthwhile. The engineer said no, these days the computer is tuned for optimal efficiency and the only way to improve performance is with a new tune. If the computer senses a different air flow it will try to offset it.
If you are installing a supercharger then yes it is worth it but that will also come with a new tune. I have been tempted to put a Magnuson into my truck but have not pulled the trigger. Trying to figure out how to spend $8k on my truck and keep the wife happy even though I just gave her some diamonds worth about that much for her 50th. lol
#5 ·
A high-priced filter dos not flow any better than a clean stock OEM filter
While on Earth, we do not have a problem running out of airmass for an N/A engine
GM calls an intake manifold an "Air Reserve"
Even if we look at a 427 CI engine like on a C6 Z06 and look at the PCM calibration, we find
that even hitting the Rev limiter at 7,200 RPMs
A cylinder volume is ONLY 1.32 grams (0.04656163 of 1 ounce) and that is the total of air and gas combined
It is not about air volume and why the other bogus BS "porting" a MAF or TB does nothing other than could reduce performance
What is important is the airmass quality and that is what a true Cold Air Intake is about
as a cold charge of cylinder creates the best firing of if
If taking x amount of volume, and the airmass is colder than if it has more molecules per volume and that is what a good volume is
Take the same volume of air but get it hotter and the mass expands and when it does, there are fewer molecules in the cylinder and is a crappy charge so produces less engine output
Problem is every schmuck selling CAIs places it high in engine bay, and we all know which direction heat goes
So they got some big bucks BS that is sucking in the hottest air in engine bay
If looking at a real CAI as used with the Corvette
There are outside air scoops on both rear quarter panels
The filer box is isolated from the engine and has 2 flows of airmass to filter area and then goes directly into the throttlebody
Almost all 3rd party filters and so-called CAI at best change the sound of the airflow and to the waxers,
they claim that sound is horsepower gains :)
Really do what some of us do and build your OWN CAI and assure coolest outside air is being taken in
So let's hear from those that claims an air filter change gains 30 HP and another 30 by scratching up the front side of a throttlebody ! :)
If that was true, GM would that and get major gains from an air cleaner
#6 ·
As Baretta used to say at the end of the police detective show:
"....... and that's the name of that tune !!!"
Correct tuning and some performance gains can be done but it takes time, experience, and testing. It's very easy to make some "upgrade" and later discover that you have actually done a downgrade. The ONLY ways to prove performance gains is with before and after dyno pulls and before and after timeslips from the track at the Friday Evening Test & Tune runs. Not easy or cheap - more power costs money, make no mistake.
PCM calibration adjustments over time ? For a dynamic PCM it's entirely possible that it will alter itself in some negative fashion in response to fuel/air mixture changes caused by untested airflow alterations. A/F testing and dyno runs are the only way to verify positive progress. Advertising hype won't do it.
#9 · (Edited)
It depends which one you get. As ZR pointed out, a true cai does not pull air from anywhere near the engine bay but truly outside. I talked to a guy who does alot of GM truck tuning and he suggested a kit from a place called Cold Air Inductions... I did notice their airbox is a fully sealed design too.... I might try it out and let you guys know :)
The K&N made it very loud if you floor it. Sounds very nice lol but otherwise I can't tell a difference. Makes me wonder about some of these videos on YouTube where they are like "omg I can feel the power now!" Like this guy smh...
#12 ·
As is common in many Amazon and other sellers' "product reviews" there are folks who are well paid to write or produce good reviews of various products.
#13 ·
If someone wants to buy some high dollar aircleaner and CAI, to know if it really works and be able to judge keeping it or returning it as BS mod
Use an OBD scanner and record the Intake Air Temps (IAT)
In Older N/A engines, the IAT sensor is mounted between the aircleaner and the TB
Newer N/A engines IAT is built into the MAF
Engines that have boost from the nameplate have a second ITA sensor in the intake manifold as boost heats air up
and PCM also uses that IAT information
To make it simple, here I tested a vehicle, I pre-made a CAI so that I could do back to back tests within less than 1 hour, so the weather temp's about the same
First test is with some high-priced CAI & filter, weather was in low 70 F degrees
Yet recording scanner data over different engine conditions (using the "Fuel Trim Cells)
We see even with that CAI temps running 100-120 F degs, far higher than the weather temp
as the CAI is crap design and sucking in hotter engine bay temps
Engine cannot make even stock HP with that cylinder charge
Now I changed to my CAI, about 30 minutes after above test
Quickly see the IATs are now close to what the weather is, even at idle and WOT
Looking how the engine performed and min/max IAT, we see the temps are close to the weather and engine performance was good with the colder cylinder charge
We see engine got to 101 KPA of MAP, MAF output close to 11,000 Hz
IF the CAI you install does not show much better temps than the stock IAT numbers, then it is not a real CAI.
IF a CAI cannot be done as to engine bay to outside than install a Water/Methanol kit
which can lower aircharge to cylinders 30–40 F degrees lower and make a good cold charge to cylinders for performance gains
#14 ·
Another way is to monitor IAT in real time using one of the OBD plug-in "gauges" - like either ScanGauge-II or UltraGauge. You can monitor any 4 of over a dozen "gauges" where supported by the car's OBD bus.
In the STS and the Explorer I constantly monitor - at the same time - IAT (intake air temp), MAP (manifold absolute pressure), ECT (engine coolant temp) and IGN (ignition advance).
Be advised that due to unavoidable heat soak in slow conditions IAT will rise in town and it will take quite a while to get it down once on the open road. Practically NO air enters the engine at idle and the throttle is open only 7% to 10% at highway cruise speeds so it takes a while to pull that duct temp down to within 10 degrees or so of ambient.
#16 ·
Sure, you could add some PIDs that also show what the MAF reports with stock and big bucks 3rd party aircleaner
Can tell after I tuned this Z06 had boost by the MAP values
TPSCELLTIMINGIATMAFMAPECTDELTQMAFRQMAFgrmsgrmcycMapKpaCFM
100151113348352147789708365.731.249118393
100151113855352147789708414.191.415118393
100151013855352147789708414.191.305118426
36102314215142147779411111.60.38848385
100102314215142147779411111.60.38848385
1001023142501421477794113811.32648385
1001510142503521477794113811.240118412
3310261311112214761941186.410.31340370
10010261311112214761941186.410.31340370
100102613348122147619411365.731.32540370
100151113348352147619411365.731.249118393
3510251271314216758930299.320.36446366
10010251271314216758930299.320.36446366
100102513147142167589302353.881.29846366
100151013147352167589302353.881.214118391
