1 - 10 of 10 Posts
2003 ESCALADE
I am considering putting dual exhaust on my 2003 Escalade and see a few systems available for under $300. Would like to hear an opinion if you have seen and or heard these systems. I am just looking for a slightly deeper sound and i like the symmetrical look of having a pipe come out on either side (rather then just passenger side)
Here is a link to the dual exhaust systems that I am referring to:
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_mPrRngCbx=1&_udlo=250&_udhi=300&_nkw=2003 cadillac escalade dual exhaust&rt=nc&_pppn=r1
2005 Cadillac Escalade
Personally I would get a name brand and definitely stainless steel. I would do 3 inch instead of 2.5 and as far as sound I think it makes the truck sound like a Tahoe with exhaust escalade is meant to be semi quiet its luxury. Would you be installing it yourself? Why are you changing it any specific reason?
2010 Platinum Escalade, 1996 Fleetwood Brougham
I wouldn't buy from them, the ad says bendrel bent,,,,,you mean mandrel?.?.?....
2003 ESCALADE
Reason for change: my Escalade sounds too wimpy, and I also want dual pipes. Dont like the look of a single pipe.
Escalade
One thing to think about. If the left pipe goes by the compressor it might overheat it. My dual exhaust goes directly under the compressor which is kaput, but it was all bought that way so I dont know if that had anything to do with it.
2003 ESCALADE
Discussion Starter #8
I ended up buying it on ebay. Will post pics and video with sound as well as installation procedure once I get it. Should be pretty easy to install.
On a separate note, I also bought a 2"/3" drop kit (spindles, springs, extenders, shocks). Anything worth mentioning in regards to the install from somebody that has done this procedure? (I will post pics of that as well as I go through the motions of installing it).
Escalade
I would like some info on your drop kit. Can the airride and front shocks work normally or do you have to remove these? Can you post the drop kit ebay link, Id like to take a look.
Some yes as you can use drop spindles for the front and the back just mainly requires modding the rear lift/dive sensors
1 - 10 of 10 Posts
