06 STS - 1SG AWD V8 and 94 Cadillac Fleetwood Brougham
Hello all!
I really need your help. My Northstar is sick far from home and I'm lost.
A few weeks ago I started getting the P1101 P0068 P0420 codes however performance and econ stayed the same so I assumed I needed a new throttle body or the software upgrade.
Two days ago, the tank was very close to "E" when I pulled into the gas station to fill up. As I stopped at the pump, the car ran a little ruff. I filled it up and it would start. After some working the peddle, I got it started but it wouldn't idle and had a very bad miss up to 2000 RPM. I drove about 50 miles at 60-70 MPH with near normal power and typical MPG but it didn't clear up.
After checking the forum and internet, I replace the spark plugs. I also put water around the intake and injectors but found no leaks. I then removed the intake to check for leaks and cracks. (didn't find any) I didn't have an injector tester however they hold pressure and didn't look too dirty. I Got it all back together and still have the hard start/hesitation/miss problem with the following codes P0300 P1101 P0301 and sometimes P0068 P0106.
Any thoughts? What else should I check before sending it to the dealer? Do you think it is related to running low on gas or just coincidence?
thank you very much in advance for your help
Todd
Todd
