1 - 20 of 31 Posts
01 frontier , 89 Shelby CSX vnt
going to work on the ignition timing tomorrow on my 94 4.9 , needed to know what the timing is supposed to be set at and if i need to pull any wires or vaccum lines before i do it , there is no sticker on the underside of the hood or anywhere that tells me how to check/adjust ign timing
also the bolt that holds the distributor down is hidden , anyone have a idea on where exactly it is ? :banghead2
Too long since I did it. I'll have to look it up on Monday when I go back to work.
I THINK it's supposed to be 10 degrees BTDC and you put it at base timing by grounding the diagnostic connector under the dash. Hopefully someone here can verify that before Monday.
Correctamundo, Katshot..10Degrees BTDC at less than 800 RPM..Detroit manual says"Jumper pins A & B at the DLC connector while NOT in diagnostic display. SET TIMING MODE message will be displayede on the Climate Control Driver Info Center." ..Then set the distributor timing... Can't help on where to find the hold-down bolt as I haven't had to set my timing yet so I haven't looked, but I'm sure taking off the top part of the air cleaner will give you more room to look...Hope I helped some...
If it's anything like the 4.1's the hold down bolt is probablly under the distributor pretty much right under the cap facing the fire wall. You'll need a crow's foot to get it. It's a PITA to get to too.
Discussion Starter · #12 ·
interesting thing happed today ...no more ping , it rained this afternoon , so i pulled it int he garage to beging retiming the thing , then i relaized i had to play soccer mom and ferry the little bro to band...
so anyway on the way there i killed the radio and climate controll to see if it was pinging , no ping
so i probed the pcm data side of the computer , it says im sitting at 25 to 30 degrees avance btdc , this normal at idle while talking to the computer?
it also says im sitting at a water temp of 89 celcius or 192 degrees farenheight , im going to take it out tomorrow before it rains while its hot out and get another water temp reading
i read a caddy website that said to check my raditaor cap and cooling system so after i take my reading tomorrow ill go grab a cap
oh and another thing my p039 code can be caused by a old prom , is this a part i can pick up or something that needs reprogramed?
i got that info here:
http://www.caddyinfo.com/howtop039.htm
but his is a north * so im kinda wondering if it applys to my 4.9 or not , my tranny is a 4t60e tho......
as always i enjoy all the help i get here , and im loving trobleshooting this thing , that computer makes things so easy
Angela Desmond said:
Hey Scrapeyard, how'd you get that picture of me on my bike???
It's that whole minds eye thing. I'm just that good :D . We got a foxy boxer on the site. That's cool. I think I've met the most deverse (perverse, which ever :devillaug ) buch of people on this site then anywhere else.
Sorry Stoneage, it seems these boys have forgotten all about your timing problems. Boys will be boys...That sounds like a lot of advance for an idling engine, but the temp. seems about right.Although, a lot of advance will make an engine run a bit warm...Now, where were we on this calander thing? :eek:fftopic:
The timing is ok and Angela, the engine runs COOLER with more advance, not warmer.
I wouldn't try to cross-apply service info from Northstar to previous version engines. Most if not all info will not apply. I'm on vacation so my reference material is at work and I can't look anything up, but FYI a PROM (Programmable Read Only Memory) is a replacable "chip" in the ECM. You can get PROMs (both stock and custom) from many sources including the dealer.
Discussion Starter · #17 ·
its all good guys and gals , im thankful for the help ive gotten so far so the off topic stuff dont bother me at all
ok took the numbers today while it was pinging
water temp is @ 224.6 f , when it wasnt pinging yesterday temp was 192
is that still ok ? if i remember right like 240 f is bad news
timing goes clear to 17 btdc @55 mph but still around 25-35 btdc at idle
air intake temp is @204 f @ idle and 185 f at 55 mph - no wonder why cold air intakes are worth ponys
weatherman says its 95 out today
Oh, I forgot, if you want to see a picture of me, see if you can get into "The Scranton Times" archives. There is a picture of me in the sports section on Dec. 6th 1997 of me fighting Kate Sekules in the first womens pro fight in Scranton. My last name was Reiss then.I'm the blond on the right with the shoulder tattoo...
Question Kat... Wouldn't too much advance make an engine be running on the edge of detonation and wouldn't that make an engine run warmer?
Actually, detonation has no real effect on engine temp, engine temp has an effect on detonation though. That maybe what the problem is in this case. He's running a rather hot engine in rather hot ambient air. Depending on fuel and baro pressure, detonation maybe tough to avoid without some modifications to the car and/or fuel octane improver.
Years ago, many cars (mostly carburated ones) used a vacuum control valve that would allow full manifold vacuum at cold start-up, then reduce to "ported" vacuum once warmed up, and finally allow full manifold vacuum again in an impending over-heat condition. This was to improve driveability when cold, reduce emmissions when warmed up, and cool the engine if it was getting near over-heating.
We can go into the full-blown mechanics of it but to be honest, I'd probably have to hit my books first to brush-up on the theory before explaining it here. I'm sure I'd forget something and confuse us both ;)
1 - 20 of 31 Posts
