Things you will need:
GTO Calipers, Brackets, Hoses, Pads, some Grease, Brake Fluid, new Brass O Rings for the Bonjo fittings;
10,12,13,14, 17, 18, 19mm Wrenches and or sockets;
2-3hrs of your personal time and then some elbow grease... LOL...
Everything bolts on super easy no need to modify anything in order to fit all the parts... the only thing you will need to do is cut the original mounting bracket attached to the GTO hose and then once thats out of the way just slide it in the OEM hole and attach the hose on to it... then you can put the retaining clip back on and it all snaps nicely in place...
Now one thing you will loose is the sensor for the worn brake pads... since the GTO ones didn't have it you can disconnect the wires and remove them but keep them in case you ever want to go back to stock.
While at it I also changed my tie rod ends and that was real easy...
IF YOU GUYS HAVE QUESTIONS PLEASE FEEL FREE TO ASK.
