1993 STS, 1997 STS, 2002 SLS, 2007 CTS 3.6
I dumped all the old codes and now check engine light comes on. I did a code test and have 3 codes coming up....only one I can find a description for is P036...there is P034 than next one is P037.
Anyone have any ideas to the code? Or guide me to place? I checked caddyinfo.
Anyway to reset that service soon light or will it just keep coming back?
DTC P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
don't know about p034. here's a good link for the codes:
http://209.145.176.7/~090/awh/dtcobd2.html
A 1993 STS is a pre OBDII car... the codes are most likely not the same. so the P037, might not be an O2 sensor. IF you call a dealer service department, they are usually more than happy to look up the codes for you.... if they are a friendly service department.
Discussion Starter · #4 ·
The way I understand it the link is for the 96 and up (some 1995). I have a 93 STS the list I found doesnt even show a P036.
http://209.145.176.7/~090/awh/dtcobd1.html
3 Codes are as follows
P036.......UNKNOWN
A037.......Loss of Instrument Panel Cluster Data
S044.......Lift or Dive Signal Fault
Any tips on the P036?
New code....Great
Now have a new code P110 I cant find any info on it.The stuff I see stops at P099. Any ideas? Thanks... Also any tips/tricks to shutting off the service engine light? I reset codes it comes back on...
