Car left at dealer january 7th @ 3pm.
Loaner car received (2013 impala ltz w/ v6 vvt)
The next day I called dealer @ 5pm since I had not heard anything from them yet. They provided me the codes below at my request. They said they were still working on it and ended call.
Today the (15th) they called me saying they have about 3.5 hours into diagnosis time but haven't repaired / replaced anything.
My reasons for visiting are the long standing speed limited to 120mph message, adaptive cruise disabling often (showing "radar cruise not ready" on DIC), loose feeling front end over bumps (described here as likely lower control arm bushings), unable to passively enter car on passenger side, transmission acting odd as if torque converter is staying locked too long when around 45mph when you get back on the throttle it seems to kick into gear kinda hard.
U2122 - (loss of communication with radio) they ignore it, to me no big deal.
p0174 - lean bank 2 ... They aren't concerned claiming bad gas likely. Not sure how I feel about this one.
C0179 system Thermal high - excessive braking / tcs application. No big deal to them or me.
B3120 keyless entry antenna 2 performance (shorted to ground or short to battery or open) - this prevents passive entry to passenger door while locked with fob in range. They were unable to reproduce issue - until I stopped in today and showed them directly what it's doing (now they claim they will take another look at it tomorrow) so they haven't done any testing with it. They have 2 options for this fault replace RCDLR or the right front door handle assembly.
B3794 - cruise control function request circuit. They are unable to reproduce issue. For me it happens almost daily causing me to restart the car to get cruise back. There is a 10 step procedure listed for this DTC that says what to do. Depending on what passes / fails they are to replace all or some of these components: BCM, IPM, multifunction switch. They are unwilling to do anything as they cannot reproduce this issue.
Now on top of all this I have a valid service contract that they sell that covers almost everything under the sun less typical maintenance / wear items (it has replaced one MRC shock already and the PPS)
Their big saying is what happens after we replace all of these things and either it still doesn't fix it or it happens again in the future. They don't want to go to the service contract company too many times and end up with a "mis-diagnosis".
Am I wrong in thinking that they should just do the tests and follow the replacements that GM said to do?
