1 - 1 of 1 Posts
94' Seville STS
Good fresh time-serted 94' SLS engine on ebay.
This guy just finished the engine and the reserve is set at $500 + $300 freight. I would buy it for a spare but I don't want a down grade in power from my STS.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=004&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=140156157339&rd=1
94 Northstar 4.6L SLS Engine
This engine is in excellent condition, it was removed from my wife’s car.
I pulled both heads and had them pressure checked and surfaced.
I put Time-serts in all the head bolt holes and used new bolts and head gaskets.
I remove the bottom of the engine and time-serted the main bearing holes
I installed a new oil manifold, rear main seal and front main seal.
The block was re-assembled using the GM Sealant called out by the Cadillac dealer.
The injectors were removed and cleaned.
I installed a new idle control module.
I installed a new oil pressure switch.
I installed a new water temp sensor.
everything torque down to manufacture specs.
New spark plugs will be installed before shipping.
Anybody else need it?
1 - 1 of 1 Posts
