1 - 11 of 11 Posts
11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
That is my plan. Working to fix the fuel problem with the stock twin fuel pumps/ Fuel pressure controller and make it so i can go over the 590~ horsepower limit the stock fuel system has Fuel pressure duty cycle is at 100% and injectors are 118% at 598. So not good for the long haul..... After that limit is gone and i can increase fuel pressure more than what was needed to hit 598, then the Bigger crank pully goes on and i dont see any issues of hitting that goal. The tune is REALLY light on the timing so i may get froggy and max it out just to see what she can do with a little bit of racing fuel... After of coarse getting some 93octane dyno numbers....
After i hit 650 RWHP with just boost, then i will start putting boost back to stock settings and playing with L98 head and cam combos. L98s should be a cheap working replacement for our restrictive heads we have now with the swirl ports. Id say alot better than porting our stock ones and at less than a 1000 bucks a set with good valves, it seems to be a good choice for us budget guys...
As for Cams... Im going to probably try 7 profiles, from light to mighty. So that should give you guys a good idea of what can be gained and what target you guys want that will give you the gains....
Cam and head swap is a 4 hour job, So im not sure how long it will take to do all the 7 profiles and different porting numbers. But i cant see it taking me more than a few weeks total time....
cts v
you mention installing a bigger crank pulley. it seems everyone on the board has been waiting for that mod. are they available now?
Jesse,
I can't wait to see what you come up with for a head/cam car with a little extra boost.
A good set of heads is always a great way to get "free" (no reliability or drivability problems) HP and if it is only a 4 hour job, that is one easy cam swap.
I would be real interested in a mild cam/heads/boost combo that did not hurt reliability and streetability too much.
Show us the way.
Mike C
2009 CTS-V
Just insane I cant wait to see the results of the H/C packages. I bet the car is going to sound nastey if you stick with your 3" exhaust and an aggressive cam. I would say 700+ rwhp is in your near future with no nitrous!
2004 CTSV(killed), 2005 CTSV(killed that too). 2004 DTS.
Just gotta give you respect. You seem to be the Chef of the 2009 V. So, you have 7 cams and are going to try them all? Thats wild! How many sets of heads or will you just clean up the stockers? Is a shop doing it or are you doing the work?
2009 CTS-V , 2010 SRX 2.8T
Sounds awesome. With heads/cams/etc we could probally hit 600 w/ barely any increase in boost. Although like you said fuel is an issue
Discussion Starter #9
Fuel is 100% the issue right now. As was with the nitrous.. It will be figured out. Just gotta get tricky..
Wow 118%. Seems awfully high even for just fooling around.
I always though anything near 90% IDC was pushing it.
What do you consider safe for a DD?
Discussion Starter #11
Safe for daily driving is 80-90 % duty cycle. Anything over 100 is impossible as it means the injector is just fully open at that point.
For 90% duty cycle the fuel system is limiting the car at 580 RWHP. So any higher is potential for failure at this point.
1 - 11 of 11 Posts
