That DOHC being the Ecotec this is quite a little engine!
Check this out:
For a 2.2L DOHC 4banger WITH NO VVT! (OMG HOLY CRAP)
that is a freakin FLAT torque curve for such an engine... Honda can't touch that.
I like the Ecotec, and when it gets supercharged, you gotta see what its going to do to the torque.....
Its funny though... GM has the Ecotec, yet people still claim GM is behind Honda...
the Ecotec can be built up to 1000HP... it is all forged internals (IIRC) and the stock bottom end can support around 400hp or so.
If I was buying a 4cylinder, you'd sure bet it would be an Ecotec.... this engine is so advanced that they were able to help the DOHC not only make this a decent engine for running around town, but also high revving HP.
This is among the very few 4 cylinder gasoline engines used in a car I actually like... alot.
Materials
Block: Cast Aluminum
Cylinder Head: Cast Aluminum
Configuration
Displacement: 2.2L (2189cc)
Compression Ratio: 10.0:1
Bore x Stroke: 86.00 x 94.60mm
Firing Order: 1 - 3 - 4 - 2
Valve Configuration: Dual Overhead Camshafts (4 valves per cylinder)
Horsepower: 140 @ 5600 rpm
Torque: 150 @ 4000 rpm
Assembly Sites:
Tonawanda, NY
Spring Hill, TN Saturn applications only (Spring 2002)
Kaiserslautern, Germany
Valve Lifters:
Hydraulic Roller Finger Follower
Fuel System:
Sequential Fuel Injection
Horsepower:
135 @ 5200 rpm (Saturn L-Series)
140 @ 5600 rpm (Cavalier, Sunfire, Grand Am, Alero)
143 @ 5600 rpm (VUE)
145 (108 kW) @ 5800 rpm (Opel/Vauxhall Applications)
145 (108 kW) @ 5600 rpm (2002.5 Opel Vectra)
Torque (lb-ft):
142 @ 4400 rpm (Saturn L-Series)
150 @ 4000 rpm (Cavalier, Sunfire, Grand Am, Alero)
152 @ 4000 rpm (VUE)
150 @ 4000 rpm (Opel/Vauxhall Applications)
Fuel Shut Off:
6500 rpm
Emmissions Controls:
Evaporative System
Catalytic Converter
Exhaust Gas Recirculation (Opel/Vauxhall Applications)
Positive Crankcase Ventilation
Air Injection Reaction (Saturn L-Series)
(CA: Automatic or Manual; Federal: Manual)
APPLICATIONS
Saturn L-Series (base)
Saturn VUE (base)
Saturn ION
Oldsmobile Alero (base)
Pontiac Sunfire (base)
Pontiac Grand Am (base)
Chevrolet Cavalier (base)
Opel/Vauxhall - Astra, Zafira, Speedster, Vectra
MATERIALS
Exhaust Manifold:
High Silicon Molybdenum Cast Nodular Iron
Fabricated Stainless steel
(for Saturn L-Series equipped with A.I.R.)
Camshaft:
Cast Nodular Iron
Cylinder Head:
Lost Foam Cast Aluminum
Connecting Rods:
Forged Powder Metal
Crankshaft:
Cast Nodular Iron
Intake Manifold:
Composite
Lower Crankcase:
Additional Features:
Extended Life Spark Plugs
Extended Life Coolant
Electronic Throttle control (VUE
and Opel/Vauxhall Applications)
:cool2: :cool2: :cool2:
