Anyone change the differential gear ratio? I see it's mentioned often on Camaro site.
S Sal329 · Registered 2008 CTS Joined Dec 5, 2014 · 161 Posts Discussion Starter · #1 · Mar 8, 2015 Only show this user Anyone change the differential gear ratio? I see it's mentioned often on Camaro site.
FunkZ · Registered 2009 CTS4 Premium & 2021 Blazer 2LT Joined Jan 19, 2015 · 940 Posts #2 · Mar 9, 2015 Only show this user According to this http://www.cadillacforums.com/forums/2008-2013-cadillac-cts-performance-mods/264465-axle-ratio.html the 3.70/3.91 that fits the Camaro won't fit the CTS rear. So it seems you're stuck with the 3.23, 3.42 or 3.73
S Sal329 · Registered 2008 CTS Joined Dec 5, 2014 · 161 Posts Discussion Starter · #3 · Mar 9, 2015 Only show this user Guess I need to start with finding out what gear ratio I have
FunkZ · Registered 2009 CTS4 Premium & 2021 Blazer 2LT Joined Jan 19, 2015 · 940 Posts #4 · Mar 10, 2015 Only show this user Check your RPO codes. GU5=3.23 GU6=3.42 and GT4 I believe is the 3.73
S Sal329 · Registered 2008 CTS Joined Dec 5, 2014 · 161 Posts Discussion Starter · #5 · Mar 11, 2015 Only show this user 3.42 is what I'm coming up with by my vin
cawengr · Registered 2011 CTS Performance Coupe -3.6 DI 6 Speed Manual Joined Apr 22, 2005 · 639 Posts #6 · Mar 12, 2015 Only show this user GT4 is 3.73 posi
F f6bbagger · Registered '10 cts4 wagon Joined May 10, 2015 · 193 Posts #7 · Oct 9, 2016 Only show this user If you have all wheel drive is a rear end gear still a possibility?
FunkZ · Registered 2009 CTS4 Premium & 2021 Blazer 2LT Joined Jan 19, 2015 · 940 Posts #8 · Oct 11, 2016 Only show this user You would have to change the front gearing to match, and AFAIK the only factory option for AWD was 3.23
