On my 2007 AWD SRX V6 when slowing down the gear shift moves back and forth. My transmision also seems to have a high pitch whining noise at acceleration and cruising speeds. With my foot on the gas pedal at cruising speeds 40km to 120km there is a high pitch noise but when i remove it there is no noise. Anyone have these problems?
Premium Member
17 XTS Platinum V-Sport; 17 Buick Envision AWD Turbo; 10 Lincoln MKS AWD Twin Turbo
1. High pitch. I had it in my 06 v8 (ver soft high pitch) when the radio was on or I was using the onstar phone; also heard it sometimes when braking. Did not bother me that much = I never addressed it. I have it in my new Escalade too when using the ONSTAR phone.
2. Shifter: you need to have the dealer check your shift interlock I think. My father in-law had a similar complaint in his DTS (vibration in shift handle), and that was the diagnosis.
91 Allante (gone), 06 SRX (gone)
My shifter moves slightly, too. I've learned to live with it.
Dealer adjusted linkage and no more moving shifter. Shaved the front rotors and also they found 1 rear tire was defective and replaced it. They balanced the tires with them still on the car (dry balance?) and all is smooooth now!
They could not find the noise i complained about but i havent herd it since i got the car back.
Next thing i need looked at is the ultra veiw sometimes will not close! I have to pull on it while it closes. Engine idle is rough and worse with the AC on.
