1 - 18 of 18 Posts
G
anyone have any ideas on where to mount some gauge pods? I really need to mount an A/F ratio pod somewhere, maybe one more. Any ideas that wouldnt look horrible?
08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
I will post up a pic of where My new boost Gage is going. I'm not at my car right now and it's easier to show you than tell you. Ryan
2013 OBM CTS-V Coupe
I say pillar or custom corner dash pod.
I don't have any. I have built custom pods with the car audio "Grill Cloth" trick. PM me your phone number and I can explain. It will take too long to write it out.
I tried to call you but your Google "secretary" would not let me through. Call me at 877-787-8989 ext 9801.
06 STS-V, 94 Fleetwood TS
The Magden M1B computer plugs into the OBD port and then to the AV ports in the console. You get a couple dozen different gauges to choose from, a few gauge styles and several background skins.
2006 STS-V and 2007 STS-V The Murdalac
Cool system! You also have a lockpick so you can see it while driving then?
That is correct... a lockpick is required to see these gauges while in motion. I have had the lockpick for so long I take it for granted. Good call Tim!
G
Discussion Starter · #15 ·
I'm 90% positive that Magden doesnt accept wideband A/F sensors or provides displays. Which is why I asked where to mount a standard gauge.
The Magden system does accept external sensors and has available add-on cards and harnesses for them. As I went to their website to get part numbers and such, I noticed that they have ceased production of the unit entirely. They have also taken down the "products" section of the website so the only hope is to find a used unit... not likely.
Full details are in the owners manual http://magden-auto.com/dl/m1_manual.pdf
I don't have mine permanently mounted. When I need, I mount the box under the driver seat with the OBD cable routed under the rocker trim. The output cable then goes up to the console and plugs in to the A/V port. There is also a USB port and flash drive for logging data and moving it to a PC where it can be opened in Excel.
Show Off!!
Just kidding. I tried to buy one last year and they were gone.
2014 Cadillac CTS VSport
1 - 18 of 18 Posts
