1 - 14 of 14 Posts
F.Y.I. Had my 6800 mile V on the dyno on Friday, and was getting poor readings. It was decided to add 10 gallons of fuel since it had roughly 4 gallons in the tank. The added fuel brought performance back up. Apparently the Cadillac persons that More Performance spoke with when they ran into a similar problem earlier were aware of the need for keeping fuel in the tank above 1/4.
What I learned from this is to be sure and have enough fuel in the tank if I am planning on really running it up near redline.
Rob
Discussion Starter · #4 ·
Results were 317 RWHP,319 RWFPT.
1/4 means in the tank, the gasoline gauges seem to be set up for idiots who need two gallons in tank after it says it is empty. I just zero out the fuel used indicator when I fill up so I know what has been consumed and what remains.
I do not know about other performance cars. The Cadillac has what it considered only one tank. It has plumbing that goes from one side of the tank to the other, which I assume is there to balance the tank which is configured more like two saddlebags. The technical reasons for all this escape me.
What type of dyno does MP use? Reason I ask is I saw much higher numbers at the place near me and their fan was meager at best, so that was probably on the lower end of things with little airflow. That was also at 515 miles, so not terribly broken in. The slips are on another thread (search for 'dyno' in this forum) but my best pull was 332rwhp.
Just wondering why there is the discrepancy, that seems quite low for a V.
It sort of depends where the pickup is. If its in the front of the tank, it can be a problem when you are on it hard. (throws the gas to the rear). This has been a problem with other models.
Static, like on a Dyno, it shouldnt make a difference.
Somewhat unrelated, but after letting the car cool down after the first dyno pull it pulled almost 10rwhp higher (same fan, etc). I think it was left maybe an hour, maybe 45 min or so. You could hear the difference in the sound of the car on the 2nd pull after the cool-off period.
Dyno's do vary but this was a problem with fuel and the lack of it. We have a direct link with GM engineers because of the fuel problem we are having with our Procharger kit. He had the same problem we had at the beginning of our installation. We are working directly with them and are not the only company seeing this problem. We will hopefully correct this by the weekend as GM is sending us new parts for the fuel system. Better in there eyes.
Amber Huneycutt
More Performance Inc.
704-393-8241
1 - 14 of 14 Posts
