1 - 8 of 8 Posts
Just thought I'd post my experience. My Sentinel quit working. After some reading on here and some other places I stumbled upon an idea. AS I was testing the photocell located in the middle of the dash ... the left of two sensors there (I think it was left) with my tester prongs on continuity touching the two wires ... the lights started to work automatically as they should. So I bought a $5 pack of ambient light sensors from radio shack. Like daddy long legs with only two legs. I think they were 5mm ... anyway ... all I had to do was pull the top off of the sensor ... pull the old "sensor" out of it's holder ... very easy ... the new radio shack ones slide right back in it's place and fold over the stems just as the old one was. push the sensor back in it's original harness and you're good to go. Waited for night time and it worked perfectly ... all for $5 (this photocell as I searched and searched ... appears to be obsolete)
2003 Deville Base
Nice write up, and good for you doing a repair on the cheap. My question is, where did you find a Radio Shack?Most of ours in north Texas are gone.
Nice writer, and good for you doing a repair on the cheap. My question is, where did you find a Radio Shack?Most of ours in north Texas are gone.
... ordered it online although near Cincinnati I do believe we have one left. I found the idea of an ambient light sensor on a remote thread somewhere ... but I didn't know how easily that little bugger would fit right down into the older sensor! It worked great!
2012 SRX Luxury
Radio Shacks still exist as "The Source" in Canada. Although, you can't get there right now cause the border is closed. The next best place would be someplace like Digikey electronics or Mouser or the like.
Steve
I've had good luck with common and oddball stuff from
HD wirewound resistors and other stuff from
Like oddball clocks? Nixie clocks are the ultimate Russian retro .........
1 - 8 of 8 Posts
