2003 DTS
Hey guys im new to the site. I have a 2003 Dts and my driver side window works whenever it wants to. I have BDM U1714 as a code. Any help would be greatly appreciated.
2010 DTS
Maybe an intermittent switch or motor?
Please post the code definitions along with the codes. No one has them memorized and it will make it easier for others to help you.
2002 DTS, 70 Cougar conv, 2020 XT4
Intermittent electrical failures can be frustrating to find. You can either wait for it to fail outright, then it's easier to find by tracing the lack of power from the motor circuit back with a multimeter; or check all wiring now for a loose or bad connection or an intermittent switch. It's less likely to be the motor itself if that runs normally (when it does run).
There is a Driver Door Module (DDM) inside the door that controls all the window functions, so start there, and check all wiring connections coming & going from that. Also be careful taking the door panel off - it uses push-in clips & you don't want to damage the panel (there is a special tool to take the clips out, but you can do it with 2 small screwdrivers if you are careful).
Getting a Factory Service Manual (FSM) either from eBay or Helm will pay for itself if you intend to do any work on your car.
And welcome to the forum.
