Great info. Exactly what I want to do. Thanks.yeah a guide would be nice.. I just replaced my reverse lamp with bright white LEDS, in the owners manual it shows you how to replace (With pics) the reverse/license plate lights and tells you the bulb type
Not sure what the turn signal bulbs are. But, to get to the headlight assembly, to take it out, you must take off the entire bumper. This is what I had to do to change my Halogens to HID's.... Big Pain in the @ssHas anyone figured out what the front turn signal bulbs are on the hid setup is? It bugs me that they used incandescent when everything else on the exterior is led. Also if anyone knows how to get to them that would be great too. It looks pretty inaccessible from the hood. Perhaps from underneath.
Where did you get the LED bulbs for the license plate, i cant find them anywhere. It adds a nice touch to the caryeah a guide would be nice.. I just replaced my reverse lamp with bright white LEDS, in the owners manual it shows you how to replace (With pics) the reverse/license plate lights and tells you the bulb type
The interior dome lights, the trunk light, and the license plate lights are all (194 bulb). The Reverse lights can use either a (194 bulb) or a (921 bulb). They have the same wedge base, but the difference is the 921 has a bigger bulb.Where did you get the LED bulbs for the license plate, i cant find them anywhere. It adds a nice touch to the car
The interior dome lights, the trunk light, and the license plate lights are all (194 bulb). The Reverse lights can use either a (194 bulb) or a (921 bulb). They have the same wedge base, but the difference is the 921 has a bigger bulb.Can you guys link to specific ones? When i search on superbrightleds there are varying size of actual bulb for each type. The only lights i plan on replacing are trunk, license plate and reverse. I tried leds in the cabin once before and it was simply annoyingly bright and i felt like i was on a podium.Also, how about these bulbs:
