tim said:
Can someone tell me where the fuel pump relay is located on a 1993 deville? 4.9 engine
on a 1992 Seville it's behind the fuse box in the engine compartment. on the driver's side wheel well, under a plastic shield. You can't see it until you take off the shield. Deville is probably in the same area.
take off the long black cover under the dash on the passanger side look by the door hinge its the 2nd relay from the top on the right side. there is a sticker on the black cover thjat tells you what the relays are for and the fuses
