1 - 14 of 14 Posts
not anymore 2007 Lexus ES350
Ok so i know and i understand
that
So i know and understand that there are 3 brand to look for when buying the fuel pump that would be the Same OEM Delphi or acdelco pumps that where in the Car's new
what i am curious about is
I ordered a Ac-Declo MU1791
From a Place that sells parts on Amazon
i picked it up for 114.xx $ Dollars
they sent me a Delphi FG0182
DELPHI Part # FG0182
Witch from rock auto says it's
To Chassis No YU145368
My Vin is YU181326
witch means i would think this would not work
but the company AD Autoparts is telling me in a email
MU1791 is an ACDdelco part number, the difference in the chassis has been eliminated and they use only one pump for both chassis. Do you want to return the product?
So they are saying that even thought Rock Auto says its for the 1st Design witch is Before my Vin number
that it will still work in my car witch should have the 2nd Design
Is this true
or are they Full of it
and just trying to excuse the fact they shipped me a part number that i did not order ?
all i know is
the part they shipped me
is FG0182 E3533M
and from what i think i know
i need the MU1791
FG0162 E3518M
any help on this would be much imprecated
I did see there is a pigtail connector with what looks I be like the 2nd design plug in the box with the pump so that d what it's for even thought I bought a pump that was supposed to be 2nd design they send me the 1st design with a pigtail connector
Ok so if i understand correctly
than this 4 wire pigtail harness
plugs into the top of the Fuel Pump correct ?
and then the plug that is part of the car wireing itself that plugs into the pump gets cute and then you use the butt connectors to splice the four plugs ABCD together
and then your all set ?
or am i missing something still ?
I have two fuel pump assemblies for a 2001 - 2003 Seville on the shelf. One has the square round pin OEM connector - direct plug-in. The other has the later flat 4-blade connector that you must splice into the existing wiring harness - an 18" or so cut back. The wire codes and procedure are in the white sheet instructions with the DELPHI/UltraPower/Airtex 3518M fuel pump assembly.
The later flat connector (splice-in) eliminates a potential high resistance connector problem with the OEM square connector.
I thought that T P installed a new fuel pump assembly about two years ago - the fuel tank level sender problem.
Discussion Starter #9
Ranger said:
Now you need a fuel pump?
No I need a fuel level sensor but I found the pump for 114.00 so figured I'd just get the entire pump and not just the level sensor
Ranger said:
Maybe it's time to take it off life support.
vincentm said:
And get TP into a Honda..
But the SLS is SOOOO close to having NO original parts left!!!
The key, one visor, the speedometer needle, and the light bulb under the hood. That about cover it TP?
Discussion Starter #11 (Edited)
The pump I have the box says Delphi fg0182. E3533M
What is the difference between 3518. And 3533. Is it just the plug ?
Or I the. Fg0182. E3533M not going to wok for mine witch is the 2nd design ?
Your close. Don't forget the passenger rear headrest. And glove box door and home link buttons those are original also and I think the left tail pipe also
What is the difference between 3518. And 3353. Is it just the plug ?
so - with all those new parts -
the car averages out to a 2010 - WOW -
Discussion Starter #13
naw i was thinking more like 07 08 consider alot of the OEM parts probably where built around that time even thought they where replaced around that time also lol
but i guess still the Big question comes down to is this going to work ?
i mean the pump says FG0182 E3533M
it has the Newer Connector in it
was there really any different other then the connector for the E3553M and E3518M ?
Discussion Starter #14
i was still upset they sent me the part diffent than what i ordered they said it would still work but even if it does work im not intrested in dealing with a company like that and chancing it
my pump works fine starts up right away no issues
so ill just replace the fuel level sensor
i sent the pump back for a refund
ordered the SK1035 Level sensor on amazon for 75.00
should i also replace the Fuel Pressure sensor whyll they are in there with the pump ?
not getting any codes from it
but just wondering at they known to fail at any specific amount of time ?
its 2 years old with 50k on it i think
1 - 14 of 14 Posts
