Any one replaced a fuel injector on the 2.0T motor? If so where are they located? I got a check engine light and started missing. Put the scanner on it and got P0301 and P050D. The care is just shy of 60k so I did plugs and swapped the coil packs. The P0301 did not go away or move to another cylinder. Researching the P050D leads me down the fuel supply road. I got a new injector for it and maybe I'm stupid but I don't see the fuel rail where I would think it should be. I have a All Data subscription for the car but they are basically worthless for a breakdown process or even a diagram of the motor. The location in their description says middle of the motor over the cylinder, but it sure isn't there unless it is under the valve cover.
Thanks if Advance,
Tyson
Thanks if Advance,
Tyson
