well i should add that some of the defects found on impalas are fixed on the fleetwoods like the uncentered rear wheels or missing body bushings on some caprices etc.
i don't know if it was different engineers or later production times but i'm pretty sure the fleetwoods have some defects not found on impalas and vice versa so check it out it might be a possible on our fleetwoods too the other thing you should look into is a faulty fuel gauge meter which can be corrected with a cheap kit on impalassforum it adjusts for the misreading causing the car to run out of gas even when the gauge still reads low-1/4 of gas
