1 - 13 of 13 Posts
I have a 1979 Eldo, and I was doing an oil change and the guy at the auto store advised me to go ahead and change the fuel filter.
I was assuming it would be a fairly easy job, but I can't find the filter?
The manual states it is located on the Left front side of the engine, but I don't see anything that would look like the filter.
Anyone know where this thing might be?
White Diamond 2001 STS
What engine? If it's carbureted, the fuel filter is likely at the inlet at the carburetor. If it's fuel-injected, it's likely a canister-looking filter that could be somewhere in the engine bay. I would look up the correct part on Rockauto.com and see what it looks like -- and then try to find that piece (in the absense of good advice, and I don't think I gave you any).
The engine is the 350 gas engine with fuel injection. I have the actual filter, and have looked throughout the engine area and don't see anything that appears to be a canister for it.
Sorry, I'm not that familiar with your particular vehicle. If you don't get any further help here, try an AutoZone:
http://www.autozone.com/in_our_stores/znet.htm
They apparently have this new computer program in their stores that shows you pictures and how-tos.
1997 SLS
Adding to this...my 97 SLS has a mysterious location for the fuel filter too...it's somewhere around the right rear wheel well of all places. I doubt your older eldo has that location, but if someone can pinpoint where they are on mid 90's Sevilles, I be grateful. Next time I rather change it myself too.
I have heard of the right rear well deal. My dad's Pontiac Bonneville had that.
I will check with autozone. The Eldo manual says "lower left front of engine" but I don't see a damn thing there.
1970 Eldorado Fleetwood
I have a 1970 Eldorado. On my car, the fuel filter is actually inside the fuel pump, on the driver's side of the engine. My fuel filter is about the size of half a pack of Life Savers.
According to my Chilton's manual, they stopped that after '74 and the filter is in the carb behind the fuel inlet nut (75 - 89 carbureted engines). On fuel injected engines on 76 to 79 vehicles, except the Seville, the fuel filter is located in the engine compartment near the fuel pump.
On the 76 to 79 Seville, the fuel filter is located on the left side of the chassis, just ahead of the rear axle. It looks like a ball of fun to get to.
Hope this helps!
Oooh, one more thing!
If it's fuel injected, the fuel will be under pressure. Save your flesh and disconnect the battery and relieve the pressure before trying to replace the filter. Fuel sprinklers are only funny once.
2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
Why not just follow the fuel line from the engine backwards. If you still cannot find it, a previous owner may have eliminated it for a different set-up. That is always fun.
Don
Discussion Starter #10
If I do find this thing, and my guess was it was up under the fuel pump area where I can't see from above, but if I disconnect the battery, is there any else to be done to relieve the pressure?
This sounds like way to much of a hassle and possible risk, eventhough I don't know how old that filter in there is.
Locate the fuel pressure service fitting on the fuel rail. It looks like a tire valve. Put a rag over it and bleed the fuel pressure. Just like letting air out of a tire. You'll get about an oz. or less of fuel out of it. The other method is to pull the fuel pump relay and crank the engine.
1 - 13 of 13 Posts
