1978 Coupe Deville
So the car has been sluggish on acceleration and I figured it would a be a good thing to clean the carb a little and replace the fuel filter. Well, the fuel filter on the 78 is so tight in between the carb and the compressor, that it is virtually impossible to get a 1" open wrench in there. Is there a special tool needed or do I need to disassemble half the car to get this seemlingly simple job done? :thepan:
1978 Coupe Deville
thanks jayoldschool, I will try it that way, it should give enough space then to be able to gain good access.
1978 Coupe Deville
update: moved compressor out of the way, had full access, but the nut on the fuel line simply wouldn't turn. Tried WD 40. Then I turned so hard that the wrench slipped over the hexagonal and now the screw is rounded somewhat...damn (I should have used a flare nut wrench!). I think I can still try with a flare nut wrench, but just to make sure, the nut on the fuel line is losened by turning COUNTER CLOCKWISE just like other screws, or is this different thread? Am I turnign the wrong way. Never encountered such a strong nut...:bomb:
86 DeVille (RIP), 89 Brougham D'Elegance, 95 FWB
they can be incredibly stubborn. Not much you can do but soak it with penetrating oil and try again. the fitting on my line was rounded quite a bit when i bought the car. the best tool for the job is probably a pair of vice-grip pliers. Also, if you can manage to find some Kimball Midwest penetrating oil, that's the best stuff on the market, beats the hell out of WD-40 or Zep.
