my fuel door will not open, nor will the trunk release work. checked the rear fuse block, went to the convenc fuse, and the was good. then i went to the maxi fuse center, and could not find it:bigroll: i know that ranger or one of you vetrans know what is causing this issue. when i went to the rear fuse block, i first checked the pzm, that was ok too. any insight would be greatly appreciated. thanks, tom
