2003 STS w/BoseNav, 1993 Deville, 1985 Deville
Hmmm....bad Fuel Pressure Regulator? Bad fuel pump? Clogged fuel filter? Pinched fuel line? Vacuum leak? Clogged injectors?
Cadillac Technician
none
Lean fuel trims are usually caused by a vacuum leak.
You could have low fuel pressure which could be caused by lots of things, but I'd start by testing for a vacuum leak. I am sure someone could suggest a few methods.
I use a can of carb cleaner or brake spray but I also use the scan tool and watch the fuel trim readings as I spray. It's easy to see the numbers change but hard to "feel" the rpm change as you spray unless you hit the leak dead on.
