Frozen Door Frame Prevention?
I did a search to no avail, so I am starting a new thread. This question is not unique to Cadillacs but I’m seeking reliable advice, which is a rare commodity on the Web. I thought the folks here would be a good place to start.
[“Do you know of a proven technique to prevent door frames from freezing shut in the winter?”]
The problem is that in the very cold weather the door frames of my 2005 Escalade ESV, presumably including the sealing gaskets, freeze the doors shut. The issue is not the locks but the doors themselves. When this happens I, sometimes, can gain entry by unlatching the mechanism then slipping the tips of my fingers between the door frame and body above the window and just above the running board.
As I can only get just the very smallest tip of my fingers in there I have very little leverage. When it is 10° my fingers are rendered non-functional in very short order.
Does anyone have any creative ideas?
Suggestions for lubricants to apply to the rubber gaskets? Are the freeze points elsewhere, such as particular metal to metal contacts? Spells? Magic potions? Anything?
Thanks for taking the time to read this.
