1 - 10 of 10 Posts
'05 SRX V8, '99 STS '05 Trailblazer '97 BMW 328ci
The front washer fluid does not work, although the rear does. I checked the two pumps and they are not leaking, I followed the line and it is not disconnected. I was wondering if there is a disconnect under the fabric heat - cover? Any advice on how to remove it?
SRX 07 V8
Hi
You say not leaking, I assume you hear the pumps actually working? Try to disconnect the line, maybe some debris got in and plugged it off, The pumps are really hard to get to. it could be the pump works bu the suction is plugged. here is one out of 05
(1) Washer Solvent Container
(2) Rear Window Washer Fluid Pump
(3) Windshield Washer Fluid Pump
(4) Headlamp Washer Fluid Pump (CE4)
(5) Washer Fluid Level Switch
here is the routing
If you have to get to the line above the fire wall you need to remove
Thank you SRX93, diagram posted is very helpful and yes the headlamp washers work.
SRX 07 V8
I assumed you opened the hood and with key on you engaged the button for the W.washer and heard the motor run? If you find the problem be sure to post so it will help others troubleshoot
Will do. Yes I checked it with the vehicle engaged, I'm going to have to go through the diagram in more detail and probably take the heat shield off. By the way, the left front used to work with a small stream but not at all now.
Then I'd assume the line and / or nozzle is plugged.
You could probably swap lines with the headlamp washer pump to test it out (just have to have headlamps on when you spray for it to engage).
SRX 07 V8
Vehicle engaged? I hope not motor running? I doubt all your nozzles are plugged but if you waxed the truck, they can get plugged. But start with the nearest point you can disengage the hose and test it, the pump is at the bottom of the tank so maybe the suction is plugged, if you do need to replace, clear a pump, its no easy task, you need to remove the wheel and inner fender liner
Discussion Starter #10
The line burst under the heat shield. It has been a South Carolina car and we had a deep freeze and I'm assuming that is how it happened. (the washer fluid in it had no "anti-freeze" in the reservoir) Thank you all.
1 - 10 of 10 Posts
