1 - 11 of 11 Posts
· Administrator
Get to the boondocks and perform several consecutive aggressive stops from 60 mph. After a stop do not hold the brakes - drive away and do it again. Does the vibration lessen or go away? Pad resin deposits/hot spots on the rotors. No improvement is usually due to worn suspension/sway bar bushings or tires or alignment. Rotors don't "warp" - that's why they're machined from gray cast iron.
Get into these whitepapers and do some pad/rotor study. https://www.apcautotech.com/brands/centric-parts/stoptech
· 2004 Deville base
'05 SRX N*/AWD, Vetts/Birds/Trucks
when i get to 58-60 mph and touch the brakes there is a strong vibration till it gets to about 50 mph. do you think its rotors?
Maybe, and likely. BUT, a few things to ask. Hilly or long downgrade braking lately? A few 'lowspeed' hard stops might change it up if it glazed a little...maybe make it worse...a crapshoot.
A recent 'detail' where to much of 'something' was sprayed on the rotor(s) 1 or both sides, or through some road puddle of unknown stuff.
Mud/crud added or falling off from winter use or after a wash or good rain or a less than careful balance with junk in/not washed out of the wheel. A good balance includes washing/degreasing the inside of the wheels.
Wheel bearings 'sometimes' add to the deal, with the other variables, there is a lot to look for.
The dynamics of a wheel spinning, and slowed down from the center and offset, make some interesting situations.
GOOD TECHS will find it in less labor time than unneeded parts costs/labor.
Good shops will figure it out, others will throw new parts on till it works. Unfortunately, many times it is the owner that has to know what is wrong to avoid overcharge/unneeded parts.
I take it there is no vibration from 35-65-even to 80(the max here) with no braking.
· 2004 Deville base
"perform several consecutive aggressive stops from 60 mph. After a stop do not hold the brakes"
Exactly what I should have said re the 'possible glaze/unknown'.
Funny, I was schooled by a truck driver and a chauffeur/hire drivers, dad/granddad, feather it to a un-noticeable stop. Drink your coffee! Brakes last a loooong time typically, I see 100k often. Maybe not on the 'hotrods'.
Now my wife, not so much. She tests tires/shocks and coffee agility on every stop. Every. :(
2003 Deville base
Discussion Starter · #6 ·
no vibration under 45 or so. i noticed the vibration on a trip which i was running on interstate roads and slowing at different towns, no rain or anything like that. might be alignment.
· Super Moderator
2010 DTS
I had the same problem several years ago, only at a slower speed. Long story short, it turned out to be corrosion on the REAR calipers. I SWORE it was in the front end. New rear calipers solved the problem. Bottom line, don't assume it's in the front.
Under normal driving, they won't warp, yet, I have warped 2 times
- 92 Fleetwood, caliper got stuck, heated up the rotor till glowing. Stuck on the rotor, rotor cooled down at different rates and warped.
-91 Celica, racing down a mountain (yes, stoopid and influenced). Smoked both the fronts, warped.
1 - 11 of 11 Posts
