1 - 2 of 2 Posts
have 04 v w/ 10k miles. the front f1s are worn: flat/NO tread at outside shoulders, to wear bars in the middle, and 1/64 of inch left until wear bars at inside of tire. is this normal wear for f1s or should i pop for a fe alignment when i install ds3s??? please limit coments to knowledgable and constructive. thanxx and merry xmas.
Lemon Law'd '05 V
If you are ripping-up the corners, then all is well...perhaps you need more negative camber.
If you don't shred the corners, then you certainly need more negative camber and an alignment is needed.
-ace
1 - 2 of 2 Posts
