Have had my '06 SRX V8 since almost new. The front tires wear on the outer edges very badly - too much positive camber. The dealer says the alignment is within spec. Firestone says the same. I say so what! There evidently is not enough camber adjustment built in to the design. I told the dealer they should sell these cars with a disclaimer about tires and wear! Now, with 50k miles, the second set is ready to be replaced. The second pair are Bridgestones while the 1st pair were the Michelin's. Both last a max of 25k. Rears replaced at 35k.
Anyone else have issues with front tire wear? Was it helped or cured by using the 255's on all 4 corners and rotating?
PS - pads and rotors replaced at 30k, wter pump replaced, idler pulley replaced - what next?
Thx, Gary
Thx, Gary
