2006 Escalade, 2007 DTS
My 2007 DTS (Lux I) just hit 90,000 miles on the factory front struts, and I suspect it's time for replacement. They don't appear to be leaking, but they're definitely pretty rusty looking and I think the front end feels a bit more floaty than I remember it. Looks like a fairly straightforward DIY job (I am reasonably mechanically inclined) so I was looking at options for complete loaded assemblies on RockAuto and I am not sure what brand to go with...
FCS came up as the cheapest option @$127 (Canadian) followed by Monroe, Gabriel & KYB all around the $180-190 mark, and finally AC Delco Professional at $206.
I googled FCS and they seem to have pretty positive reviews, so I am kinda leaning that way since it'd save me about $120, but I do plan on keeping the car around awhile longer so I want something that'll last and give me a proper Cadillac ride.
For those of you running replacement struts, what did you choose and how have they held up?
Go with the correct AC Delco struts and mounts with Monroe as a second choice. You will regret going cheap - big time.
basscatt is the Deville/DTS suspension guru.
Your suspension code is on the sticker under the spare tire cover. FE1 is the less expensive soft, passive spring/suspension. FE3/F55 is the expensive active "sport" suspension.
2003 Deville Base
I second Sub's comment. Monroes on both of my cars. If you have the FE3/F55, be prepared to open your wallet very deep.
DTS '06 Lux II + Sunroof
I've purchased my replacements from AutoShack just a few weeks ago and I'm quite pleased with what I got for the price I've paid. They're slightly stiffer, a wee bit higher but not clunky and, most important, the ride feels good again. Also, I paid the extra 30$ for the lifetime warranty (One-time replacement) .Note: I have an FE1 suspension.
If you decide to do the job yourself, the torque specs are 44lbs-foot for the 3 upper strut mount bolts and 108lbs-foot for the 2 strut-to-knuckle bolts. I would recommend purchasing a tube of blue thread locker at your local Princess Auto or Home Depot (I used Permatex). Also, I strongly advise using jack stands in tandem with your floor jack for safety.
If you need to replace one of your strut-to-knuckle bolts, you'll find replacements at your local scrapyard for cheap. Just look for any GMC Acadia/Buick Enclave/Chevy Traverse/Saturn Outlook as they use the same bolts & nuts. You can also ask for part #14087888 at a GM dealership, should cost about 25$ per bolt.
Thanks guys. My car is FE1, so at least I've got that going for me.
2006 DTS perf
2006 DTS Performance Lux III
When working properly the performance mag ride is awesome. smooth in the city and perfect for the highway.
