Front grill emblem
1 reading
6.9K views 11 replies 6 participants last post by  Weatherfx
Can you remove the front grill emblem on a 2016 with out removing the entire front of the car? I noticed there is a few tabs holding it on but not sure if i could pry them off from the front. Not to worried if i break them cause i am replacing the emblem. I also don't want to damage the front grill tho trying to get it off. Thanks.
#3 ·
I also thought I would be able to get to the front emblem by taking the vanity cover off, but when I had my grille changed out on my '19 it looked like it would be very difficult if not impossible to get at the emblem just by removing the front vanity cover. I would say at minimum the top push pins that hold the fascia to the metal support would have to be removed, the front fascia carefully pulled forward as much as safely possible and then reach inside to undo the emblem clips (long thin arms would be an asset). But there is the hood latch mechanism to get around and the wind dam as well. So even with pulling the front fascia forward, it would be quite a task to try and get to.
Here is what the '16 looks like
Here is what mine looked like after the vanity cover had been removed and new grille installed which required the front fascia to be taken off.
Here are the clips that hold the emblem on. You have to push down on each one and then forward to pop the emblem forward.
