I have a 2000 deville with 170,000
i have replaced
control arms with ball joints
tie rod ends
sway bar links
springs and shocks all the way around
front wheel hubs
power steering hose
when doing the power steering is there a way to bleed the line or do not have to?
now i have a wobble or vibration at 60 to 75 mph it goes away when i accelerate the tires are good still now when i turn i notice a little bit of a ratchet feel to the wheel so i am thinking inner tie rods or am i looking at a rack and pinion any help would be appreciated
As far as bleeding the PS system, manufacturer's procedures were usually to take the weight off of the front wheels and then, engine off, turn them lock to lock a few times. Not sure if they've changed recommendations at all, but I don't see why they would.
That said, if you've driven the vehicle some, the PS system has already bled itself through use.
did you get the car aligned after replacing the control arms and tie rod ends cause those will knock the car out of alignment and explain why there is a vibration at them speeds
i will double check the tires i have a second set that are new so i will put them on and see how it rides the ride was smooth for around 8000 miles after all the work was done it was aligned and the alignment is still good something just feels funny in the steering it feels like there is some play but i cant figure where i was checking the front end for the 3rd time this week end and when the wheel is turned all the way to either side i have a lot of slop or movement if i straighten the wheel no play thanks for the help
if i turn fully to the right and check the passenger side the wheel moves in and out quite a bit but the driver side does not but when i turn fully to the left the diver side has play and the pass side does not i am thinking i should have no play i still have to check the tire by putting a different set on and test drive
OK, with the wheels off the ground, do you get play when grabbing the wheel at 9:00 & 3:00 or 12:00 & 6:00? 9:00 & 3:00 = worn tie rod end. 12:00 & 6:00 = wheel bearing wear (hub & bearing assembly).
Same problem here! Well actually my problem is when i hit the brakes, my left front tire looks like its slightly turning inwards as if you were turning right. then when you let off the brake it releases and returns to normal position. All new front end parts / alignment. I'm thinking its the inner tie rods. Slop between 9 & 3.
New struts
Tie rod ends
Control arms w/ball joints.
Hub / bearings.
Worn out bushings in the new control arms? You said they were new but that pic looks like an old one. Glad you found the issue but I would guess that not only myself but several others would have suggested those bushings if you hadn't told us the control arms were new
Believe it or not they were purchased in FEB 2012. dorman is the maker. Now the right side is showing similar signs.....
BTW the picture is of the factory part for reference only. I would have assumed the bushings as well but considering new control arms, I wouldn't have even began to think it was the problem. I'll never again buy Dorman parts. Sure they are cheap but is it worth it? Not in my case. You get what you pay for.
:yeah:
The Dorman branded arm (second one so far on the STS!) has had a bad bushing that causes steering shift during braking (otherwise appears normal, but can be moved with a lever.) Need to look for another brand to use...
