When going over large dips in the road, such as gravel driveways with pits in them, i get a minor clunk noise. Anyone have this problem before? It isnt a loud clunk, just an audible one. Any advise is appreciated. thanks
2001 STS. I have had codes for secondary air pump for a while but ran ok. Now the car will start but when you put on the gas the engine spits and sputters and will not accelerate. . No new codes since but won’t hardly run
Hi all, I have a P0300 Misfire Code. I am in the early stage of searching for what to investigate as the cause. I suspect that the cause is a vacuum leak rather an a bad coil pack.
Last night in the dark I was shining a light around and noticed that this pipe looks loose. Maybe the clamp is...
just got this 85 seville, was it me or who designed that spare tire location. It may have been me but trying to keep the tire up and put that hold down to stay up and then screw the bolt on I had to climb into the trunk. Hope i never get a flat.
Hello!
I'm not very good at classic cars! This is our first retro car.
Friends please help pick up oils and fluids for this car...
Engine, transmission, axles, antifreeze ...
In your opinion, how often do you need to change fluids in this car?
I'll be very grateful! Thanks!
Engine: 425 CID V-8...
Id say 50% of the time I have to turn the key more than once for the caddy to start. Would this be a starter issue? I just had the car tuned up last week. Plugs, wires, and fuel filter. This was a issue before the tune up also. Thanks
