94 ETC
94 ETC, When I step on the gas from a stop I am getting a clucking/knock sound that appears to be coming for the drivers side wheel well. I hear/feel it when I go over large bumps, like railroad tracks. Could this be swaybar links and and bushings and if so is there a way to test for sure. Any help or suggestions would be great.
1996 Deville (sold), 2000 Mustang GT
There's a couple different things it could be. Bad end links, tie rod ends, ball joints, or a shock mount. Easiest way to tell is to get under the car and start pulling/pushing on each component, which ever has play in it, is the culprit.
94 ETC
Dog Bones were my first thought and I replaced them but to no avail. It's weird I had the front tire off the other day and was yanking on the links but there was not much play. Car was only up on the supplied jack so I didn't want to yank too hard. The knock is hear also when I shift from park to reverse or drive. When I hit the gas from a stop, and sometimes when I take turns, or go over bumps. It's driving me nuts, and I just want to find the problem and fix it, so fustrating!
1993 ETC, in Windsor, Ont.
Don't forget the inner or outer tie rod ends!
Easy way to find that is to be at a stop, and violently whip the wheel back and forth, and see if you can reproduce the clunk.
