1 - 11 of 11 Posts
2003 Deville Base
left front corner light is out so I figured this would be a good time to convert to LED. No problem getting the headlight assembly out, but can't figure out the corner light. Does it twist or what? Maybe if I could get the whole harness apart I could get at it on the bench, but the multi-wire plug won't come off. Any suggestions?
rab? I could probably see it better if I could get the main plug off.
rab?
MC has fat fingers and a broken screen -
I think TAB is what he was going for -
but - I could be wrong -
I do have banana fingers, but my screen isn't broken... not yet anyway.
Yes, tab. Fixed. :alchi:
2003 Deville Base
Discussion Starter · #6 ·
I have skinny fingers, but evidently a brain issue. I didn't mean cornering light, I meant the side marker. It's a 194 bulb inside the headlamp assembly. Even my skinny fingers can't get in there to twist or pull or whatever it needs. Any other thoughts?
long nose pliers
Hmm. Sure you're going about it right? I have very big hands and don't have an issue changing bulbs.
If you do put a tool to it, don't twist too hard.
2003 Deville Base
Discussion Starter · #9 ·
MC, the headlight and turn signal bulbs are no problem, but the side marker light is in the housing to the upper left of the turn bulb. Other than long nose pliers or surgical forceps I don't see any other way to get to it.
Yeah I know the bulb, just don't remember there being an issue changing it :noidea: .
long nose pliers -
1/4 turn - and pull -
1 - 11 of 11 Posts
