1 - 2 of 2 Posts
94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
Looking for opinions. Anyone with proven methods? What's the best way to remove the rear driver side freeze plug on a SBC? I've only through experience removed one with a chisel and a slide hammer. Has anyone drilled a hole and screwed into one? What about using a punch on the edge to rotate the plug about, grab it with a channel lock or vice grip? I'm installing a block heater, and this time, I'd prefer not to have the plug come out after 2 hours of swearing and slide hammering.
Brian
94 Fleetwood Brougham
In the car or out? Sounds like in the car. That sucks. I worked with a guy had the rear freeze plug on his 350 Pontiac Grand Prix rust out or come out on him. This is the one between the block and flywheel.
I think I did one once, punch and hammer to get it cockeyed and then grips to lock on and yank it out. So, you pretty much already had the idea. Took a lot to get it out. I leave them alone most of the time.
Make sure it is square in the hole. And only in as far as the other ones are, don't go too far.
1 - 2 of 2 Posts
