Got A 97 Eldorado. The Longer It Sits The Harder It Is To Start. In The Am It's Most Difficult. In The Tech Tips Section It Describes The Problem As The Opposite Not Starting When Hot. Could The Fuel Pressure Regulator Still Be Causing My Problem?
I think you are on the right track. Electronic fuel injected cars should start quickly when properly maintained.bobb said:Got A 97 Eldorado. The Longer It Sits The Harder It Is To Start. In The Am It's Most Difficult. In The Tech Tips Section It Describes The Problem As The Opposite Not Starting When Hot. Could The Fuel Pressure Regulator Still Be Causing My Problem?
