Turn your wheels in (different direction for each bulb). For example, turn your wheels to the left to change out the passenger-side, and to the right for the driver-side. Pull out the forward-most bottom clips that hold your black wheel-well covers (inner fenders) in place. Peel back the inner fenders, and you will be able to see the wires leading to your fogs. Pull enough clips out that you can comfortably get your hands in there. Just twist and pull at the base of your fog lamp assembly (like changing any other bulb). Good luck!
