I have been having trouble with my fob on my 2009 STS. In order to lock the car i have to find that “sweat spot” to lock it. Remote starting is another issue, i have to lock twice then hold my hand at different angles in order to remote start it. I am wondering if my fob is worn out and needs to be replaced or if it is a problem with the car.
2008 STS Northstar RWD, 2000 Trans Am WS6 6 spd, 1968 LeMans convertible 6.6
How old is the fob battery
Well then, ask him if he ever put a battery in it. Could be a low/almost dead battery. Or you could go somewhere and get it checked. Or it could be a failing fob, from what you are describing.
2006 STS4 4.6L
"Sweat spot" LoL 😥
Must be playing "warmer.. warmer.." With the fob.
At any rate, you can find replacement batteries for a pretty good deal. I think I bought 4 for not too expensive and I keep the extra 3 in the center console. I've also seen electrical interference disrupt the reception of the fob signal.
2006 STS V8 1SF RWD
Crack it open and clean the back side of the rubber buttons, check to make sure the contacts on the board surface is clean as well.
Sent from my Pixel 3 using Tapatalk
