1 - 2 of 2 Posts
2004 Caddy DeVille : The Foam piece that fits above radiator under the rad support members. what's the correct way of installing it ?
2002 Deville and 2009 DTS
The foam is a tube that is triangular shaped.
It goes in front of the radiator support and UNDER the hood bracket support. just slide it from the sides. or you can loosen up the support and lift it up and push it through.
1 - 2 of 2 Posts
