I recently bought a 1991 Seville, and ive noticed that there is a fluid leak in the front left side under the car. It is a pinkish fluid in color and was just wondering if anyone knew what it was.
2011 SRX4 3.0 4WD Luxury
yea agreed probably a rad hose clamp.....but they also make a pinkish washer fluid......
transmission fluid, check the hard /rubber lines between the trans and radiator, probably a loose connection, or a pan gasket ( if you have one) be DAMN sure to check the trans fluid ASAP - ASAP consult your owners manual.if its a rubber line - replace all of them and have the fluid changed..keep the receipt for resale...
2001 Deville
2004 Deville
I'm guessing if the op can't identify trans fluid he doesn't have the skills to identify what's leaking or fix it so Shameer my suggestion would be to ask your friends and neighbors to recommend a local independant garage and have them take care of it for you. stay away from the chain stores if you want the car fixed correctly for a fair price
