I agree. I probably will not need the full capability, but I would enjoy knowing I have extra overhead in case.
And you are correct. Probably be running around E30 - E40 but might like to play at higher levels from time to time
. From discussions maybe up to E70 is possible.
I have all Tapout stuff: Stage 1 LPFP, HPFP internals and the cams. I asked Scott for the widest E range possible while still being safe and he got me to E75. I don’t make anymore power above E60 but I wanted the extra margin in case I mix wrong or the ethanol has an unusually highly content that throws my calculations off. Just remember the more E in the tank the harder the fuel system works. There’s no reason to tax the system more than you have to and I try to keep my max mix at E63-65.
Honestly if you go all out on the fuel mods…Once you put that kill tune in that’s what you’re gonna want to run majority of the time. It’s way faster than the flex tune you can get and it can be addicting. If you’re thinking you’re going to spend all this money and not use the car to it’s potential you’re probably mistaken.
Here’s my experience and advice, specifically if you’ll be dyno tuning: I have the kill tune and the flex tune only. I only use the flex tune when I want to run 93/switching between kill tune and 93. If I knew what I know now I would have gotten a tune specific for 93 when I had the work done. My point is if you’re going to run E and you have a fully upgraded fuel system, you’re gonna put E60+ in it, I promise you. As far as running ethanol (at least for me) the flex tune is necessary to allow the fuel to mix while driving after filling up, or going on a road trip, but that’s about it. I don’t ever find myself thinking I just want 75% performance this week so I’m stopping at E40. I’m either putting 93 in or I’m taking advantage of the capabilities I paid for with the E60+ tune.
The flex tune is great and necessary but if you intend on using specific various fuel levels like E30 or 93 then get tunes specifically for that as well so you can optimize the vehicle for that fuel. The flex tune is versatile and makes great power but you’ll give up performance at any specific fuel level for the versatility. For instance my flex tune makes between 464 at E0 and 570 at E75 to the tires. A 93 specific tune for my setup should make around 525. An E30 tune would probably be around 550. You can see how much power I’m leaving on the table with the flex tune at any E% vs a specific tune. I’m probably giving up 40whp with 93 octane and an E30 tune is encroaching on the max my flex tune does with E75. The flex tune is necessary and I’m glad I have it but if you’re going to run a couple specific fuel blends get tunes for those in addition to the flex tune. Use the flex tune for road-trips or when switching fuel concentrations, otherwise pick the fuel you want and run a tune for it. Do it all at once while you’re on the dyno and then enjoy the car.
