1 - 2 of 2 Posts
93 fleetwood brougham
Hi, I have a 1993 fleetwood brougham with 45k on it and I'm having trouble with it staying running. It will run for anywhere between 5 and 30 mins before it just dies, it doesn't sputter it just dies. I'll try to start it and it won't start just turns over, I'll come back and try to start it later and it starts up. I've changed the fuel filter rotor cap plugs wires. Still does it. Anyone ever have this problem? Please help the weather is perfect and I miss her.
2.. 95,94, fleetwood brougham's
Hi there when your Fleetwood dies, do you still have your display and working lights etc...and has it ever done it when your driving? or when it is just sitting there at a idle. And when is the last time your fuel pump was changed, I will have to look this up but, I think the fuel pumps are on a circuit breaker. If these (breakers) don't function the right way they can cause failure in what ever component there protecting.(like your fuse panel in your house) but I'm not 100% sure, I will check for you. Chris
1 - 2 of 2 Posts
