1 - 12 of 12 Posts
2010 DTS Premium
I noticed last night when I pressed the flash to pass I would hear like a clunking noise or banging noise. Has anyone else ever had this problem or hear a noise when using flash to pass? Thanks.
2011 DTS Platinum
Did this noise just start happening????
I have never noticed a noise doing the FLASH TO PASS when I was inside the car...
If I am OUTSIDE the car... I can hear the "EYELIDS" open and close...when changing from dim to bright and back again... but it is too little of a noise to hear it from inside the car.
Texas Jim
2010 DTS Premium
Discussion Starter · #4 ·
Texas Jim
Yes it just started last night. I never ever heard any noise from "inside" the car when using flash to pass. The lights and system work but they just make a loud noise like a bang or clunky noise.
2011 DTS Platinum
I would make a wild guess, that one of the eyelids have come loose inside the light assembly.
Or the STOP adjustment is off calibration.
Try this... open the hood...turn the lights on... and have someone do the FLASH TO PASS while you stand at the front of the car.
You should be able to then locate the exact area that the noise is coming from.
Texas Jim
Some additional - explanation. Cadillac decided that turning on the HIDs and then moving the shutters (low to high beam) would be too slow and would represent extra wear an tear on the HIDs (high voltage startup, etc.). So, as Texas Jim says, the Flash-to-pass only works when the HIDs are already on (same thing for the CTSs with HIDs). His suggestion that something associated with the shutters has come loose or is way out of adjustment, if you didn't hear the noise before, is probably correct.
2010 DTS Premium
Discussion Starter · #10 ·
grilco, have you been able to resolve this problem yourself yet? Thank you for your time.
Jeff Morris, Cadillac Customer Service
As of yet No. I have to make an appointment with the dealer but I can't until I can get some time off work. My neighbor and I checked his 08 DTS out and his was very quiet with no banging or clunky noise. If I find out anything sooner I'll post it in the forum. Thanks.
2006 Cadillac DTS (Black Raven)
Mine does the same thing too. I can hear it from inside the Cabin. It doesnt bother me as I rarely use it. :lildevil:
1 - 12 of 12 Posts
