97 Cadillac SLS
Well I aquired the car needing head gaskets about a year ago. Haven't had a chance till now to get it apart and running. I pulled the motor last week and when i went to pull the heads I noticed that the exhaust cams were retarded a bit and the intake cams were advanced a bit. What i am trying to determine is if this was done on purpose or it was an accident when someone changed the timing chains or something? I may need to have the heads decked a few thousandths to make sure they are flat and not warped so valve clearance and timing is a concern since i dont know a lot about the n* yet. Is it common to change the cam timing in these motors in that manner, and what are the ramifications tuning wise to doing this?
There is absolutely no advantage in advancing or retarding the cam(s) in a Northstar. The old adage that advancing a (single) cam 4 degrees moves the power band down about 800 rpm and the opposite from retarding it the same amount does not hold true in a DOHC engine. The Northstar is an interference engine, meaning that, if you mis-time the cam(s), you run the very real risk of one or more sets of valves hitting the pistons.
Time the cams according to the GM/Helm Factory Service Manual or subscribe to www.alldatadiy.com.
97 Cadillac SLS
that is what i thought. I just found it odd that the cams weren't timed 90* to the top of the head. They were both off a bit.
97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
I know the intake cams can cause valve-to-piston interferance but I don't think the exhaust valves can, as they are recessed further into the head and on a different angle. I'll have to check next chance I get. The pistons have valve reliefs too, but they won`t help in the event that a chain should snap....
