1 - 20 of 26 Posts
07 CTS-V Maggied
I put up a couple threads about my "hanging throttle" that I would get which was almost impossible to drive with.
The only way that I could stop this problem was to disconnect the battery for 30 minutes and it would go away for 100-200 miles
I was finally fed up to the top with it, and drove it for a little bit before I took my car in to the dealership the next day. On my way home the night before the check engine light comes on. I said "great". not only this stupid hanging throttle, but now a check engine light.
Took it in and they fixed the Clutch Positioning Sensor. Got the car back, and wallaaaa. It was fixed. I think my problem was I kept resetting the battery too fast and the code never got a chance to pop up, which in case never made the check engine light come on.
I was just confused because before I had this worked on 5000mi prior to it happening now for the same reason.
Is this a part I can have replaced? Can these go bad? I dont want to have this happen again and again
Thanks,
Ryan
2016 ATS Premium 6-spd MT
Sorry I didn't follow your post real well, but I'm glad you got it fixed.
Oh, btw, it's not "wallaaaa" ... it's voila, I believe.
07 CTS-V Maggied
hahaha. You tried helping me before on this matter. To get down to the point. The clutch positioning sensor was making my hanging throttle. The only way to fix it was to reset the car by disconnecting the battery. I kept doing that, and there was no time for the check engine light to come on.
Hahahahhahaha. Randy, I think you are the only person that could get away with saying this.
Ryan - I'm glad it's finally fixed.
Au contraire ... I bow down to the great, the one-and-only, the true master at correcting the English language: tbjs. :worship:
Wait a minute ... that's French!
So, can anyone tell me how the clutch positioning sensor ties into the throttle?
Just wondering
Hey, you're getting back on the subject!
Actually, I was wondering the same thing, but that "wallaaaa" hijacked my brain there for a moment.
Yeah, how does that work ... anyway? The only connection I know of is the human body ... you know, up the from the clutch pedal into the left leg, thru the nether regions, then down the right leg to the gas pedal. Is there another connection?
But, Ryan ... however it worked, glad you're back on the road.
05 CTS-V
:lol: Thats crazy talk...
Only thing I can think of, is that switch is for the cruise control. Ya know, when you push the clutch in while in cruise, it cuts cruise off. I guess if that switch is bad, it could make your throttle stick...
Just a hypothesis
G
There is programming in the PCM that shuts off fuel when you push in the clutch. It is called clutch fuel cutoff, much the same as decel fuel cutoff. I'm sure it has something to do with the effects of this.
05 Stealth Gray CTS-V, 08 Light Platinum SRX V8, 05 White Diamond STS4 V8 1SG
I should check that with my cheapo scantool. These cars hit DFCO on clutch-in and the revs STILL drop that slowly? Man these flywheels are great...
07 CTS-V Maggied
Discussion Starter · #12 ·
Yeah, I really dont know how it worked, but it obviously had something to do with it because now it is gone.
There was three symptoms that would occur when I had this hanging throttle issue. This might help you guys figure it out
- The hanging throttle/RPM's (when trying to switch to next gear, you have to wait 1-2 seconds before the RPM's come down to match ur next gear)
- When downshifting from say; 3rd to 2nd. Usually ur RPM's hang for a second so you can match ur downshift. As soon as you would engage the clutch in third to switch down to second, RPM's drop dramatically fast down to idle, thus making the RPM's have to climb all the way back up
- When getting on it, and shifting in considerably high RPM's. It almost seemed like the car was dying for a split second after each shift into a gear. Like it had no fuel and there was no responsiveness through the throttle, but then a split second later it would come back alive and you would go back into your acceleration. Then next shift, the same thing happens
Hope this might help a little bit
Whoa. This got my attention. My car has done this multiple times, usually on the 2-3 or 3-4, at high rpms. No stability control, just a momentary loss of power. I wonder if that's a sign that the clutch switch is on its way out. Very interesting. Does the rev limiter or throttle work differently with clutch in vs out? If it thought the clutch was still disengaged, maybe it wouldn't allow actual WOT until it saw the clutch switch close (or open...whatever). I'll see if I can find anything in HP Tuners.
07 CTS-V Maggied
Discussion Starter · #14 ·
I SPOKE TOO FAST F*CK............ It's back again, and I am taking my car in and not picking it up until they fix it. Kevm14, did tuning ur car help at all? This is the only time I dont want to drive my car; and its sad cause I always love driving it.
I'm gonna try and get a video
Does anyone know if the clutch positioning sensor can go out?!?!?!
I haven't tuned my car yet because I haven't purchased HP Tuners. I just downloaded the demo and have been familiarizing myself with an LS6 CTS-V stock cal. I didn't see anything about a clutch switch/throttle control interaction. The TAC module doesn't take any input directly for clutch position so it's either hard coded in the PCM, or the issue is caused by something else, like torque management.
04' Blown CTS-V 554rwhp 497rwtq
OP is your car stock?
If not there are various tables within HP Tuners that allow for adjustment of the "hanging throttle" and "hunting throttle" (revs dip and raise then find the target idle speed). They are the throttle follower and throttle cracker tables and can be a PITA to work with.
As for the clutch in DFCO that Brian was talking about I have been playing around with this table myself. It cuts fuel for a moment when you clutch in but seems to be less beneficial for my 18lb. flywheel and the added drag the blower places on the motor. (It seems to cause a slight lag when shifting into the next gear). But I digress that is my situation and not yours! :) Hopefully though it makes some sense for you of what could be happening.
2004 CTS-V
Yeah, still have it...... did u get the same issue with urs?
Yeah, I had that lofty hanging throttle when I had them off. Could have been a complete coincidence or a placebo effect when I had them welded back in, but the issue seemed to go away. I probably had my car in for work around that time so it could have been something else..
07 CTS-V Maggied
Discussion Starter · #20 ·
We'll if it doesnt throw a code this time, hopefully a tune will help it
as for mods just a K&N CAI, muffler delete, and short shifter
1 - 20 of 26 Posts
