1 - 20 of 47 Posts
Cadillac 03 DTS
My 03 DTS was running like crap last week and I came online to see if you guys had similiar issues with codes P0171 P0174, and discovered that my plenum might be the issue. I purchased the plenum from my local Caddy Stealer for about $ 30 and got the intake gaskets for about $ 17 at Napa ( stealer wanted $ 7 a piece) I removed the fuel rails, intake etc and discovered the plenum had a huge crack on the bottom. I swapped it out put on the new intake gaskets and put her back together, the whole job took about an hour and a half and the car hasnt ran so good in the three months since ive owned it. Not bad for a certified shade tree tech. I attached pics might help you guy out there having the same issues
2001 Cadillac Deville
your pictures helped out alot I drove home with codes and after I was done no Codes YES!!! thanks for the pics. I had a tear about a QTR of the way around the Plenum
2001 DTS, 2005 Mustang GT, 2010 MINI S
When mine did it, at first I thought I had some bad gas. Problem started just after leaving a gas station.
Anyway, spraying some carb cleaner around I could hear the leak at the plenum.
Ripped plenum, exactly like yours.
Mine was like $20 at the dealer. The intake gaskets can be reused if not damaged.
Logan Diagnostic LLC
www.ledfix.com
www.airbagcrash.com
www.logandieselusa.com
'98 STS (RIP @ 206,xxx miles)
How do these things develop rips like that?
It sure would be nice to hear from you-know-who on this issue. I don't think we had any reports of similar problems prior to the 2000 model year engine changes.
Material? Vendor? Design? Beats me.
2018 CTS 3.6L AWD Premium Luxury, Previous: 2009 STS 3.6L AWD, 2003 DTS 4.6L
My guess would be heat. Has me wondering if maybe I should do a little preventative maintenance and change it before it goes bad.........
Jim,
Pre 2000's did not have the plenums. I think the TB was bolted directly to the manifold, which then brings up the question, why the change?
Yeah, would be nice to hear from him. I tried to email him recently, but his email address was undeliverable and I don't have his personal address. Even if he was to come back, it would be under a different name and he would never divulge his identity again.
There should be absolutely no movement between the TB flange and the intake manifold: they're both bolted to the same block, so that sort of rules out excessive flexing.
All the "plenum" problems with cracking appear to occur in the bottom 30 - 45 degrees of the bellows edge. Might this have something to do with a combination of fuel vapor (where from?), oil (PCV) vapor, and the fact that the bottom of the plenum bellows is a natural sump for holding liquid nasties? The GM fix might be as simple as a change to the ingredients used to mold the plenum in the first place, and a real hard look at the molding wall thickness in the break area.
Too bad you can't just clamp a piece of silicone intake hose in there........straight wall, impervious to fuel damage.
I see no reason why you couldn't.
I think the plenum has a clamping plate on the TB end, not a simple spigot with hose clamp setup.
HOWEVER, an enterprising tuner could have a spigot welded to the (removed and cleaned....) plate, and make the necessary TB gasket......
2002 Cadillac DTS Deville on Vogues and DTS Blades
maybe i shouldnt ask but who is this mystery member you guys mention?
The General himself or what?
Almost........I believe the person was heavily involved in the design, testing, and validation of Northstars and running changes. That's 55th party hearsay.........
I won't mention his screen name as he asked that we let it die a swift and silent death when he left (not that I think it matters anymore), but he is a GM powertrain engineer. He was a great asset and taught us a lot.
1 - 20 of 47 Posts
