2001 DTS
On the DIC Feature Programming is set to off and will not let me turn it on.
What do I need to do to activate this?
2001 DTS
Drivers seat will not move at all.
But the lumbar works.
Could this have something to do with
FP not working?
I checked all fuses
Steering wheel will move to position
But not seat.
Would the seat memory module being bad cause
this to happen?
Only code present is Catalyst Low Efficiency code that has nothing to do with seat....
IGN ON in P
Press MEM 1 button
Press INFO until FEATURE PROGRAMMING displays
Press On/OFF to enter
begin scrolling through features.
Do you have an owner's manual ?? ..........it's all in there.
2001 DTS
Yes I have manual and I have read it and re-read it.
The odd thing is the pass. seat operates normally,but the drivers does not move.
Once I`m in feature programming i can scroll through the options but i can not turn any of the remote memory functions on,such as remote memory,key on memory,etc.In fact on the main DIC display when feature programming is shown it is set to OFF,I can't enable it for some reason.
If the memory seat module was bad...
Could that be keeping me from adjusting any settings and/or turning on certain feature programs?
If you're part contortionist you might try checking all the under-seat electrical connectors. Or........
